Multiple Curve Plotting#
Some examples require external input files. Before you start, please follow the link in the Example Scripts section to download the zip file with model and result files.
Example 01 - Create Multiple Plot Layout#
Create multiple pages from channel info stored in dictionary#
1import hw
2import hw.hg as hg
3import os
4
5ALTAIR_HOME = os.path.abspath(os.environ["ALTAIR_HOME"])
6plotFile = os.path.join(
7 ALTAIR_HOME, "demos", "mv_hv_hg", "plotting", "madymo", "ANGACC"
8)
9
10# New Session
11ses = hw.Session()
12ses.new()
13
14# Dictionary with curve channel names
15plotDict = {
16 "yRequests": [
17 "50th% Hybrid3 - LOWER TORSO",
18 "50th% Hybrid3 - UPPER TORSO",
19 "50th% Hybrid3 - UPPER LEG RIGHT",
20 "50th% Hybrid3 - UPPER LEG LEFT",
21 ],
22 "yComponents": [
23 "Res. ang. acc.",
24 "X-comp. ang. acc.",
25 "Y-comp. ang. acc.",
26 "Z-comp. ang. acc.",
27 ],
28 "lineColors": ["#ff0000", "#00ff00", (0, 0, 255), (0, 0, 0)],
29}
30
31# Create fonts and colors
32fontAxisText = hw.Font(family="Arial", style="regular", size=14)
33legendBorderColor = hw.Color(rgb=(204, 204, 204))
34datumColor = hw.Color(hex="#ff0000")
35
36# Loop over pages
37for index in range(1, 3):
38 ap = ses.get(hw.Page)
39 if index > 1:
40 ap = hw.Page()
41 ses.setActive(hw.Page, id=index)
42
43 # Define page attributes
44 ap.setAttributes(layout=9, title="HG Demo " + str(index))
45 i = 0
46
47 # One plot per request
48 for request in plotDict.get("yRequests"):
49 i += 1
50 aw = ses.setActive(hw.Window, window=i)
51 aw.type = "xy"
52
53 # Add curves from dictionary
54 for component, color in zip(
55 plotDict.get("yComponents"), plotDict.get("lineColors")
56 ):
57 cu = hg.CurveXY(
58 xFile=plotFile,
59 xType="file",
60 xDataType="Time",
61 xRequest="Time",
62 xComponent="Time",
63 yFile=plotFile,
64 yType="file",
65 yDataType="Angular Acceleration",
66 yRequest=request,
67 yComponent=component,
68 lineColor=color,
69 label="{y.HWRequest} - {y.HWComponent}",
70 )
71
72 # Add curve math SAE filter
73 cu.mathAdd("SAE", padding=1, direction=1, filterClass=15)
74
75 # Create and Modify curve math trim operation
76 mathTrim = cu.mathAdd("trim")
77 mathTrim.setAttributes(start=20, end=140)
78
79 # Add vertical datum line at curve max
80 dv = hg.DatumVertical(
81 position="c1.x[indexofmax(c1.y)]",
82 label="Y Max",
83 labelLocation="upperCenter",
84 lineColor=datumColor,
85 )
86
87 # Edit vertical axis label using font object
88 av = ses.get(hg.AxisVertical, curve=cu)
89 av.text = "Max of Resultant = {max(c1.y)}"
90 av.font = fontAxisText
91
92 # Modify Header values
93 header = ses.get(hg.Header)
94 header.setAttributes(visibility=True, text="Demo Window " + str(i))
95
96 # Modify Legend Style
97
98 legend = ses.get(hg.Legend)
99 legend.setAttributes(
100 borderColor=legendBorderColor,
101 borderStyle=3,
102 placement="insideRightBottomCorner",
103 )
104
105 # Create note at maximum of curve 3
106 note = hg.Note(
107 attachTo="curve",
108 attachmentCurve=1,
109 attachmentPoint="indexofmax(c1.y)",
110 text="Max = {y} @ {x}",
111 autoPosition=True,
112 autoPositionStrategy="right",
113 curveColor=True,
114 )
115
116 # Update() recalculates, fits and draws
117 aw.update()
Figure 1. Output of ‘Create Multiple Plot Layout’
Example 02 - Plotting Curves from Single File#
Advanced Build Plots functionality via Python#
1import hw
2import hw.hg as hg
3import os
4
8)
9
10ses = hw.Session()
11ses.new()
12# evalHWC('hwd window type="HyperGraph 2D"')
13win = ses.get(hw.Window)
14win.type = "xy"
15
16dataTypeList = ["Time", "Angular Acceleration", "Index"]
17dataType = dataTypeList[1]
18
19createCurves = hg.CreateCurvesByFile()
20createCurves.file = plotFile
21createCurves.yDataType = dataType
22createCurves.yRequest = "all"
23createCurves.yComponent = "all"
24createCurves.layoutType = 1
25createCurves.layoutOrganisation = "onePlotPerRequest"
26createCurves.run()
Figure 2. Plotting Curves from Single File
Example 03 - Plotting Curves from Multiple Files#
Create Curves by File functionality for plotting from multiple files#
1import hw
2import hw.hg as hg
3import os
4
5scriptDir = os.path.abspath(os.path.dirname(__file__))
6multipleFileDir = os.path.join(scriptDir, "doe_1")
7plotFile = os.path.join(scriptDir, "doe_1", "run__00001", "m_1", "boxbeamT01")
8
9ses = hw.Session()
10ses.new()
11win = ses.get(hw.Window)
12win.type = "xy"
13
14dtIndex = 1
15dataFile = hg.DataFile(plotFile)
16dataTypeList = dataFile.getDataTypes()
17requestList = dataFile.getRequests(dataTypeList[dtIndex])
18componentList = dataFile.getComponents(dataTypeList[dtIndex])
19
20multipleFiles = hg.MultipleFiles()
21multipleFiles.name = "FS1"
22multipleFiles.directory = multipleFileDir
23multipleFiles.fileList = [
24 "run__00001/m_1/boxbeamT01",
25 "run__00002/m_1/boxbeamT01",
26 "run__00003/m_1/boxbeamT01",
27 "run__00004/m_1/boxbeamT01",
28]
29multipleFiles.labelPrefixSuffix = "dir2"
30multipleFiles.typePrefixSuffix = "prefix"
31fileSet = multipleFiles.createFileSet()
32
33createCurves = hg.CreateCurvesByFile()
34
35createCurves.file = multipleFiles
36
37createCurves.yDataType = dataTypeList[1]
38createCurves.yRequest = requestList[0:2]
39createCurves.yComponent = componentList
40createCurves.layoutType = 1
41createCurves.layoutOrganisation = "onePlotPerRequest"
42createCurves.run()
Figure 3. Plotting Curves from Multiple Files
Example 04 - Plotting Curves from Multiple Subcases#
Create Curves by File functionality for plotting from multiple subcases with MultipleSubcases() class#
1import hw
2import hw.hg as hg
3import os
4
6plotFile = os.path.join(scriptDir,'plot','10_subcases.h3d').replace("\\","/")
7
8ses = hw.Session()
9ses.new()
10win = ses.get(hw.Window)
11
12df = hg.DataFile(plotFile)
13subcaseList = df.getSubcaseLabels()
14multSub = hg.MultipleSubcases()
15multSub.file = os.path.normpath(plotFile)
16multSub.subcaseList=subcaseList
17multSub.typePrefixSuffix='prefix'
18subcaseSet = multSub.createSubcaseSet()
19print(subcaseSet)
20
21dtl = df.getDataTypes()
22rl = df.getRequests(dtl[1])
23cl = df.getComponents(dtl[1])
24
25createBySub = hg.CreateCurvesBySubcase()
26createBySub.subcaseSet = multSub
27createBySub.yDataType = dtl[1]
28createBySub.yRequest = rl[1:8]
29createBySub.yComponent = [cl[2],'-',cl[-1]]
30
31createBySub.yComponentSorting = 'descending'
32createBySub.layoutType = 9
33createBySub.layoutOrganisation = 'onePlotPerRequest'
34
35createBySub.run()
Figure 4. Plotting Curves from Multiple Subcases
Example 05 - Create XY Curve Plot Options#
Modify plot options for XY Create Curves by File functionality#
1import hw
2import hw.hg as hg
3import os
4
5ALTAIR_HOME = os.path.abspath(os.environ['ALTAIR_HOME'])
6plotFile = os.path.join(ALTAIR_HOME,'demos','mv_hv_hg','plotting','madymo','ANGACC')
7
8
9ses = hw.Session()
10ses.new()
12
13df = hg.DataFile(plotFile)
14subcaseList = df.getSubcaseLabels()
15df = hg.DataFile(plotFile)
16dtl = df.getDataTypes()
17dataType = dtl[1]
18
19createCurvesOptions = hg.CreateCurvesOptions('MyCurveOptions')
20
21createCurvesOptions.pagePublishTitle = True
22font = createCurvesOptions.pageFont
23font.size = 20
24font.family = 'Arial'
25createCurvesOptions.pageFont = font
26createCurvesOptions.pageTitleScheme = 'custom'
27createCurvesOptions.pageTitle = 'My Page'
28
29createCurvesOptions.headerVisibility = True
30createCurvesOptions.headerLabelScheme = 'custom'
31createCurvesOptions.headerText = '{y.HWRequest} - {y.HWComponent} modified'
32createCurvesOptions.headerPrimaryFontSize = 16
33createCurvesOptions.headerAlignment = 'right'
34
35createCurvesOptions.footerVisibility = True
36createCurvesOptions.footerLabelScheme = 'custom'
37createCurvesOptions.footerText = '{y.HWRequest} - {y.HWComponent} modified'
38createCurvesOptions.footerPrimaryFontSize = 16
39createCurvesOptions.footerAlignment = 'right'
40
41createCurvesOptions.legendFontSize = 8
42createCurvesOptions.legendPlacement = 'insidelefttop'
43createCurvesOptions.legendVisibility = True
44
45createCurvesOptions.curveUseMath = True
46createCurvesOptions.curveXexpression = 'u*5'
47createCurvesOptions.curveYexpression = 'v*10'
48createCurvesOptions.curveShowLabel = True
49createCurvesOptions.curveLabelScheme = 'custom'
50createCurvesOptions.curveLabel = '{y.HWRequest} - edited - {y.HWComponent}'
51createCurvesOptions.curveShowLabelPrefix = True
52createCurvesOptions.curveLabelPrefix = 'START'
53createCurvesOptions.curveShowLabelSuffix = True
54createCurvesOptions.curveLabelSuffix = 'STOP'
55
56createCurvesOptions.curveLineColorScheme = 'allOneColor'
57
58col = hw.Color(rgb=(0,255,0))
59createCurvesOptions.curveLineColor = col
60createCurvesOptions.curveLineThicknessScheme = 'allOneThickness'
61createCurvesOptions.curveLineThickness = 3
62createCurvesOptions.curveLineStyleScheme = 'allOneStyle'
63createCurvesOptions.curveLineStyle = 4
64createCurvesOptions.curveSymbolScheme = 'allOneSymbol'
65createCurvesOptions.curveSymbol = 5
66createCurvesOptions.curveSymbolStyle = 3
67createCurvesOptions.curveSymbolColor = col
68createCurvesOptions.curveSymbolFrequency = 10
69
70createCurvesOptions.curveXscale = 3
71createCurvesOptions.curveXoffset = 1000
72
73createCurvesOptions.curveYscale = 7
74createCurvesOptions.curveYoffset = 5000
75
76createCurvesOptions.curveStartIndex = 10
77createCurvesOptions.curveEndIndex = 100
78createCurvesOptions.curveIndexIncrement = 10
79
80# --------------------------------------------------
81
82createCurves = hg.CreateCurvesByFile()
83createCurves.file = plotFile
84createCurves.curveOptionsEnabled = True
85createCurves.curveOptions = createCurvesOptions
86createCurves.yDataType = dataType
87createCurves.yRequest = 'all'
88createCurves.yComponent = 'all'
89createCurves.layoutType = 1
90createCurves.layoutOrganisation = 'onePlotPerRequest'
91
92createCurves.run()
Figure 5. Plotting XY curvesw with modified Create Curves settings
Example 06 - Create multiple Complex Plots#
Creating complex plots using CreateCurvesByFile() with chart type complex#
1import hw
2import hw.hg as hg
3import os
4
6plotFile = os.path.join(scriptDir,'plot','control_arm_sol111.pch').replace("\\","/")
7
8ses = hw.Session()
9ses.new()
10win=ses.get(hw.Window)
11
12dtIndex = 1
13dataFile = hg.DataFile(plotFile)
14scl = dataFile.getSubcaseLabels()
15dtl = dataFile.getDataTypes()
16rl = dataFile.getRequests(dtl[dtIndex])
17
18cl = dataFile.getComponents(dtl[dtIndex],format='complex')
19dt = dtl[1]
20sc = scl[0]
21
22win.type="complex"
23createCurves = hg.CreateCurvesByFile()
24createCurves.file = plotFile
25createCurves.chartType = 'complex'
26createCurves.subcase = sc
27createCurves.yDataType = dt
28createCurves.yRequest = rl
29createCurves.yComponent = cl[2:]
30createCurves.layoutType = 7
31createCurves.layoutOrganisation = 'onePlotPerComponent'
32print('Component List = ' + str(createCurves.yComponent))
33
34createCurves.run()
Figure 6. Create multiple complex plots in a predefined layout
Example 07 - Create multiple Polar Plots#
Creating polar plots using CreateCurvesByFile() with chart type polar#
1import hw
2import hw.hg as hg
3import os
4
7
8ses = hw.Session()
9ses.new()
11
12dtIndex = 1
17
18cl = dataFile.getComponents(dtl[dtIndex],format='polar')
19dt = dtl[1]
20sc = scl[0]
21
22createCurves = hg.CreateCurvesByFile()
23createCurves.file = plotFile
24createCurves.chartType = 'polar'
25createCurves.subcase = sc
26createCurves.yDataType = dt
27createCurves.yRequest = rl
28createCurves.yComponent = 'all'
29createCurves.layoutType = 7
30createCurves.layoutOrganisation = 'onePlotPerComponent'
31print('Component List = ' + str(createCurves.yComponent))
32
33createCurves.run()
Figure 7. Create multiple polar plots in a predefined layout
