Query Plot Data#
Some examples require external input files. Before you start, please follow the link in the Example Scripts section to download the zip file with model and result files.
Example 01 - Get Channel Info#
Get channel info from plot file#
1import hw.hg as hg
2import os
3
4ALTAIR_HOME = os.path.abspath(os.environ["ALTAIR_HOME"])
5plotFile = os.path.join(
6 ALTAIR_HOME, "demos", "mv_hv_hg", "plotting", "madymo", "ANGACC"
7)
8
9dtIndex = 1
10dataFile = hg.DataFile(plotFile)
11dataTypeList = dataFile.getDataTypes()
12requestList = dataFile.getRequests(dataTypeList[dtIndex])
13componentList = dataFile.getComponents(dataTypeList[dtIndex])
14metaList = dataFile.getMetaDataList(dataTypeList[1], requestList[0], componentList[0])
15metaValue = dataFile.getMetaDataValue(
16 dataTypeList[1], requestList[0], componentList[0], "HWUnit"
17)
18
19print("Channel Info")
20print("File = " + plotFile)
21print("Reader Version = " + str(dataFile.readerVersion))
22print("Data Types")
23for dataType in dataTypeList:
24 print(" " + dataType)
25print("Requests of DataType = " + dataTypeList[dtIndex])
26for request in requestList:
27 print(" " + request)
28print("Components of DataType = " + dataTypeList[dtIndex])
29for component in componentList:
30 print(" " + component)
31print("Meta Data Label = " + metaList[0])
32print(" Value = " + metaValue)
Figure 1. Console Output of ‘Get Channel Info’
Example 02 - Create Data Frames from Plot Files#
Create and plot NumPy and Pandas Data Frames#
1import hw.hg as hg
2import os
3import matplotlib.pyplot as plt
4
5ALTAIR_HOME = os.path.abspath(os.environ["ALTAIR_HOME"])
6plotFile = os.path.join(
7 ALTAIR_HOME, "demos", "mv_hv_hg", "plotting", "madymo", "ANGACC"
8)
9
10dtIndex = 1
11dataFile = hg.DataFile(plotFile)
12dataTypeList = dataFile.getDataTypes()
13requestList = dataFile.getRequests(dataTypeList[dtIndex])
14componentList = dataFile.getComponents(dataTypeList[dtIndex])
15
16dataFileQuery = hg.DataFileQuery(plotFile)
17dataFileQuery.dataType = dataTypeList[dtIndex]
18dataFileQuery.requests = "all"
19dataFileQuery.components = "all"
20dataFileQuery.includeTime = True
21
22print("Numpy Array")
23numpyArr = dataFileQuery.run("numpy")
24print(numpyArr)
25
26print()
27print("Plot Pandas Data Frame")
28pandasDataFrame = dataFileQuery.run("pandas")
29pandasDataFrame.plot(figsize=(25, 20))
30plt.show()
Figure 2. Console Output of ‘Create Data Frames from Plot Files’
