*ELEMENT_BEAM
LS-DYNA Input Interface KeywordDefines a beam, discrete beam, or a truss element.
| *ELEMENT_BEAM_{OPTION} | |||||||||
| EID | part_ID | N1 | N2 | N3 | |||||
If OPTION = ORIENTATION, insert the following
line
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| VX | VY | VZ |
Definition
| OPTION |
| EID | Element identifier. (Integer) |
| part_ID | Part identifier. (Integer) |
| N1, N2, N3 | Node identifier. (Integer) |
| VX, VY, VZ | Vector to define cross section orientation. When used the
input for N3 is ignored. (Real) |
