*ELEMENT_SEATBELT_SLIPRING
LS-DYNA Input Interface KeywordDefines a 1D or 2D seat belt slipring.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *ELEMENT_SEATBELT_SLIPRING | |||||||
| SID | SBID1 | SBID2 | Fric_d | node_ID1 | Ltime | Fric_s | node_ID2 |
| A | Fl_flag | Ed_factor | fct_ID2 | fct_ID4 | |||
Definition
| SID | Slipring
identifier. (Integer) |
| SBID1 | First element or set of elements
identifier on one side of node_ID1.
(Integer) |
| SBID2 | Second element or set of elements
identifier on the other side of
node_ID1.
| Fric_d | Coulomb dynamic friction
coefficient. (Real) |
| node_ID1 | Node or node set identifier
defining the seatbelt nodes coincident with the slipring.
(Integer) |
| Ltime | Lockup time. (Real) |
| Fric_s | (Optional) Coulomb static friction
| node_ID2 | (Optional) Orientation node
| A | (Optional) Coefficient for
determining Coulomb friction coefficient. (Real) |
| Fl_flag | Direction of belt movement.
| Ed_factor | (Optional) Decay constant for
friction coefficient computation. (Real) |
| fct_ID2 | (Optional) Curve identifier
defining dynamic coefficient of friction as a function of normal
force. (Integer) |
| fct_ID4 | (Optional) Curve identifier
defining static coefficient of friction as a function of normal
force. (Integer) |
- This keyword maps to /SLIPRING/SPRING and /SENSOR/TIME.
