/FAIL/ENERGY
Block Format Keyword Describes an energy density failure model.
/FAIL/ENERGY/mat_ID/unit_ID | |||||||||
E1 | E2 | fct_ID | Xscale | I_Dam |
Optional Line
fail_ID |
Definition
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Unit identifier. (Integer, maximum 10 digits) |
E1 | Maximum energy density. 2 Default = 130 (Real) |
[Jm3] |
E2 | Failure energy density. 2 Default = 230 (Real) |
[Jm3] |
I_Dam | Damage calculation flag. 4
Default = 1 (Integer) |
fct_ID | Function identifier for
f(˙ε)
. It is the function of energy density E1 and E2 scaling factor versus strain rate. (Integer) |
Xscale | Scale factor for abscissa of the
function. Default = 1.0 (Real) |
[1s] |
fail_ID | Failure criteria
identifier. 3 (Integer, maximum 10 digits) |
▸Example (Metal)
- The element is
deleted, if D=1 for one integration point.D=E−E1E2−E1
- The energy density is the current internal
energy of the element divided by the current element volume. The value will be different
than the element time history /TH/element Internal energy (IE) which is
the current internal energy divided by the "initial" element volume.
Figure 1. Energy Density Model Failure - The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
- The I_Dam option improves damage calculation and stability calculating damage, it is not available for shell elements and material laws N° < 29. It is available for the /MAT/LAW25 (CRASURV) law, if using /PROP/TYPE51 or /PLY and /STACK options.
