/FAIL/WILKINS
Block Format Keyword Describes the Wilkins failure model.
/FAIL/WILKINS/mat_ID/unit_ID
α β Plim Df Ifail_sh Ifail_so
Optional Line
fail_ID
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
α Hydrostatic pressure exponent.
(Real)
β Deviatoric coefficient.
(Real)
Plim Hydrostatic pressure limit.
(Real)
[Pa]
Df Critical damage.
(Real)
Ifail_sh Shell failure flag.
= 1
Shell is deleted, if DcDf for one integration point or layer.
= 2
For each integration point, the stress tensor is set to zero, if DcDf and shell is deleted, if DcDf for all integration points or layers.
(Integer)
Ifail_so Solid failure flag.
= 1
Solid is deleted, if DcDf for one integration point.
= 2
For each integration point, the deviatoric stress tensor vanishes, if DcDf .
(Integer)
fail_ID Failure criteria identifier. 2
Example (Metal)
  1. The cumulative damage is:
    Dc=W1W2dˉεp
    Where,
    W1=(11+aP)α
    a=1Plim
    Where,
    P
    Hydro pressure
    P=133j=1σjj
    W2=(2A)β
    A=max(s2s1,s2s3),s1s2s3
    Where, s1,s2,s3 are the deviatoric stresses.
  2. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
