/INIBRI/EPSP
Block Format Keyword Describes the initial state for a brick.
| /INIBRI/EPSP/unit_ID | |||||||||
| brick_ID | value | ||||||||
Definition
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| brick_ID | Element
identifier (Integer) |
| value | Date
value (Real) |
- /MAT/LAW38 (VISC_TAB) is not compatible with /INIBRI/EPSP.
- The initial state for brick may be defined by more than one block.
