Working with Joined Data Table Editor
The Joined Data Table Editor allows you to join two or more data tables to create a new joined data table. This editor is composed of the following sections:
Join Data Table Editor Sections and Definitions
| Section | Description |
| 1 |
Back Exit the Joined Data Table Editor and go to the Data Library page. |
| 2 |
Join Data Table Name Name of the join data table. You can edit by entering a new one and clicking |
| 3 |
Join Data Table Settings Description of the data table and the auto refresh period (in seconds). |
| 4 |
Join Data Table Parameters Add or manage data table parameters. The inherited data table parameters from the joined data tables are displayed. |
| 5 |
Search Columns Allows searching of columns on the Data Preview. |
| 6 |
Collapse Data Profile Pane Collapse the Data Profile pane. Click |
| 7 |
Data Profile Pane Displays the following information:
| 8 |
Data Preview Execute the queries to return and display preview of the joined data table you are NOTE: The maximum number of rows displayed in the Data Preview is 100. |
| 9 |
Calculated Columns Allows you to view and manage the calculated columns. The inherited calculated columns from the joined data tables are also displayed. |
| 10 |
New Column Options Allows you to add any of the following columns:
| 11 |
When the Column Order is set to Sorted, the columns are grouped by type (Text, Date/Time, then Numeric) and sorted alphabetically. |
| 12 |
Column Profiling Perform column profiling either for the Top 1000 Rows or All Rows. |
| 13 |
Join Settings Allows you to:
| 14 |
Data Policy Allows you to set the data policy for data tables in the Data Library. |
| 15 |
Join Type Displays the join type used. |
| 16 |
Add Data Table Displays the Add Data Table dialog where you can select data tables to join.
| 17 |
Join Key Allows you to select the join keys of the data tables that will be joined. |
| 18 |
Refresh Preview Allows you to refresh the data preview. |
| 19 |
Save Join Data Table Saves the join data table definition. |
| 20 |
Join Types Allows you to define:
| 21 |
Collapse Data Preview Collapse the Data Preview pane. Click |
Clicking Transform Settings
displays the Transform Settings pane.
Transform Settings |
Allows you to perform the following:
Clicking Advanced
displays the Advanced Settings pane.
| 1 |
Error Message Allows you to enter custom Error Message that will be displayed when an error occurs while fetching data. Can be parameterized. |
| 2 |
Includes Aggregate Data Allows you to retrieve external aggregates. |
| 3 |
Export Raw Data Specify the set of columns to be included when exporting raw data |
Clicking Debug
displays the Debug pane.
| 1 |
Data Table ID Id of the data table. Can be used for parsing of server logs. |
| 2 |
Data Log Details of the data log which includes the data source name, response time, and duration (ms). |
| 3 |
Parameters Parameters in the data table. |
| 4 |
Logs Logs of the last query. |
to expand the Data Profile pane.
