Particles
Generate a uniformly distributed particles for the nanoFluidX solver.
Analysis > Particles
A model typically has solids that are stationary (outer container for example), solids that have assigned motion (gears, shafts, bearings, etc.) and fluids phases: liquid or gas inside the container. To reduce the total number of particles and thus solver performance, the closed container inner volume - wetted surface, is identified and a thick region is created with minimum thickness of 3 particle layers.
- Create Particles in SimLab
Figure 1. For particle creation, it is required to select the node inside the fluid regions. All solids that have attached motion will be automatically selected in the Moving Solids selection menu.
You can change the number of discretization layers in Advanced options.
