Shower
Create Shower
Analysis > Shower > Create Shower
Create Shower mimics the behavior of actual shower. Shower is represented using group of nozzles arranged in a certain pattern. It acts as an inlet in the water management analysis.
Create Shower in SimLab
To create Shower as boundary condition, nozzle size and shape as well as shower pattern has to be defined.
Figure 1. Create Shower parameters definition in SimLab
  • Nozzle size and shape: Specifies nozzle diameter and distance between shower inlets.
  • Shower size and shape:
    • Number of nozzles: Based on the number of nozzles specified “Along X” and “Along Y”, the number of nozzles will be created in global X and Y axis.
    • Dimension: Based on the dimensions specified “Along X” and “Along Y”, using the diameter and spacing distance, the number of nozzles will be created in the global X and Y axis.
