Hole
The hole realization is dependant.
Realization Type
- Rigid Element
- A common realization for Implicit analysis that has a single node defined as the interface.
- Rigid Patch
- A common realization for Explicit analysis that has a meshed patch defined as the interface.
Element Type (Rigid Element)
This is the type of element the attachment creates:
- RigidLink is a single RBE2
- RBE2 is series of two legged RBE2s
- RBE3 is a single RBE3
- RBE3 (Stuck Node) is a specific Aerospace implementation of two RBE3s over the top of each other with differing DOFs
Connect Outer Layer (Rigid Element)
How many layers into the mesh it will select, like
washer layers.
- None
- Just the hole
- Every Node
- Single washer layer
- Every other Node
- Single washer layer alternating nodes
- Two Layers
- Two washer layers deep
Solid Hole Nodes (Rigid Element)
How do you want it to connect to solid holes.
- Edge nodes: top and bottom edges only
- Interior nodes: select all of the nodes in the interior hole
- Face nodes: select only the nodes on the face of the solid hole
Snap to Center (Rigid Element)
Have the center of the rigid calculate based on the realization, or based on the location of the attachment entity.
Use Hole or Washer (Rigid Patch)
- Fill Hole
- Fill the hole with the patch
- Use Washer
- Create a patch on the washer layer of the hole
- Use Both
- Both the washer and the hole will be used
Create Elements (Rigid Patch)
Only available in OptiStruct, it will create a set instead of the patch elements.
