Shape
A common realization for Explicit analysis that has a meshed patch defined as the interface.
Realization Type
Rigid Element
A common realization for Implicit analysis that has a single node defined as the interface.
Element Type (Rigid Element)
This is the type of element the attachment creates:
  • RigidLink is a single RBE2
  • RBE2 is series of two legged RBE2s
  • RBE3 is a single RBE3
  • RBE3 (Stuck Node) is a specific Aerospace implementation of two RBE3s over the top of each other with differing DOFs
Shape
Box
You define the length, width, and height of the box.
The shape is centered on the attachment.
Cylinder
You define the radius, height, and normal of the cylinder.
The top of the cylinder is centered on the attachment.
Sphere
You define the radius of the sphere.
