Combine Lines
Use the Combine Lines tool to create a new continuous line segment between two existing lines, resulting in a single seamless line.
Restriction: FE geometry lines are not supported.
  1. From the Topology ribbon, Lines tool group, click the Combine/Extend Lines tool.
  2. Select Combine from the guide bar drop-down.
  3. Select lines to combine.
  4. Optional: Check the Smooth Connect checkbox to create curved connections between non-collinear lines, as shown in the following image.
    Figure 3.
    If left unselected, a straight line connection with angles is created.
    Figure 4.
  5. On the guide bar, complete one of the following:
    • Click to apply and stay in the tool.
    • Click to apply and close the tool.
    • Click to exit the tool without applying.
