WR Card
The WR card is used to define a dielectric windscreen reference plane. Geometrically this surface is not part of the electromagnetic model and is used simply to determine the curvature factor between the two elements on the windscreen.
On the Solve/Run tab, in the Windscreen
group, click the
Windscreen reference (WR) icon.
Note: The WR, WA and WD cards should be used together to create windscreen antenna models.
These three cards respectively define the windscreen reference surface, the windscreen
solution elements (antenna) and the windscreen layered media definition.
Parameters:
- Windscreen name
- The name of the windscreen.
- Use as reference all surfaces with label
- The start of the label range.
- (optionally) up to label
- [Optional] The end of the label range.
Note: The windscreen reference triangles are defined by label and since this plane also forms
the zero reference with respect to the defined windscreen antenna elements and glass layers,
they should all have their normals pointing in the same direction.
