Jump to main content
Altair® Flux®  2025 Documentation
2025
  1. Home
  2. Flux
    Flux is a finite element software for low-frequency electromagnetic and thermal simulations. Both, 2D and 3D solutions are available...
  3. Construction of a Flux project
    The construction of a Flux project consists of several stages: Geometry → Mesh → Physics → Resolution → Postprocessing; with the possibility to import a CAD file, a mesh, materials...
  4. Results post-processing: software aspects
  5. I/O parameter (Input/Output)
  • Welcome
  • User guide
    The user guide gives information about principles and how to use Altair® Flux® 2025.
  • What's New
    See the release notes of the last and previous versions, with the necessary information on new features.
  • "How to" Documents
    See a list of documents to understand how to use certain features.
  • Altair Flux Videos
    Several youtube videos about how to use Altair Flux and several tip and tricks
  • Flux Supervisor
    The Flux supervisor allows to run projects, examples, pythons scripts; to configure user preferences; to access tools...
  • Flux
    • General operation
      Here is a presentation of the Flux environment; the project management, the data management, the command language, the formulas and mathematical functions.
    • Construction of a Flux project
      • Geometry: principles
      • Geometry: software aspects
      • Geometry: Sketcher (2D)
      • Geometry: Modeler (3D)
      • Mesh: principles
      • Mesh: software aspects
      • Geometry / mesh import: principles
      • Geometry / mesh importation: software aspects
      • Materials: principles
      • Materials: software aspects
      • Coils and windings in Flux
      • Magnetic cores in Flux
      • Structural optimization in Flux
      • Solving process: principles
      • Solving process: software aspects
      • Results post-processing: principles
      • Results post-processing: software aspects
        • Introduction to local quantities post-processing
        • Introduction to global quantities post-processing
        • What is a computation point?
        • Post processing on a step (Selector of scenario / Selector of step)
        • Path
        • 2D grid
        • 3D grid
        • Computation axis of the torque
        • Cut plane
        • Isovalues/Isolines
        • Arrows
        • Animation
        • Geometry reconstruction
        • 2D curve
        • 3D curve
        • Import of curve
        • Superimposition of 2D curves in Flux
        • Export FMU block
        • Quantity computation on points
        • Computation on physical entities
        • Evaluation of the demagnetization
        • I/O parameter (Input/Output)
          • I/O Parameter (input/output): about
          • I/O parameter (Input/Output): definition (structure)
        • Sensor
        • Predefined computations
        • Computation of integral
        • Operation sensor
        • Current value of an I/O parameter
        • Multipoint support
        • Spatial quantity
        • Results post-processing: sequence of commands
        • Parametric analysis: sequence of commands
        • Computation of inductance matrices
      • Parametric analysis: principles
    • Physical applications
      Flux allows to model different physical phenomena, and includes various applications (magnetic, electrical, thermal and thermal coupled).
    • Circuit and Kinematic Couplings
      Flux is coupled to a circuit context allowing to model the sources of the devices.Flux also allow to model the movement via a kinematic coupling.
    • Co-simulation between Flux and another software
      Flux is able to couple with several softwares allowing to model mutliphysics phenomena.
    • Dedicated couplings
      Several dedicated couplings are implemented in Flux to, carry out vibro-acoustic studies, magneto-thermal studies and more.
    • 3D Overlay
      Flux has predefined models for rotating machines via Overlays allowing to describe a geometry, a mesh and a physics adapted to the wished machine.
    • Flux API
    • How to Configure the Memory in Flux?
  • Flux Skew
    Flux Skew is a module dedicated to the analysis of rotating electric machines with skewing, allowing a straightforward geometric and physical description in 2D and the consideration of continuous or step skewing effects.
  • Flux PEEC
    Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also provides RLC extraction and generation of SPICE-like equivalent circuits.
  • Material Identification
    The Material Identification tool is based on the Altair Compose environment and allows determining from measurements the parameters and coefficients required to create a material in Flux.
  • Altair Material Datacenter (AMDC)
    AMDC is a comprehensive material database maintained by Altair and partner suppliers of engineering materials. Ready-to-use, Flux-compatible models may be obtained directly from this database for a growing number of materials.
  • Material Manager
    Flux has a material manager with its own material base.The user can create his own material base and import them into the Flux models to be studied.
  • Flux e-Machine Toolbox
    FeMt is a application in Flux dedicated for Electric Machine which permits to compute and postprocess results like efficiency maps.
  • Flux Examples
    See the lists of examples 2D, 3D, SKEW and PEEC with all available documents and all project and python files.
  • Flux in SimLab Examples
    See the lists of 2D and 3D SimLab examples using the Flux and Mipse solvers, with all available documents, *.slb databases and all script files.
  • Mementos
    See a list of Memento documents to understand certain Flux features.
  • Macros
    Flux proposes several macros enabling doing actions that are not yet implemented in Flux.
  • PyFlux Documentation (Beta version)
    This documentation deals with the Jython script used in Flux and allows to understand the various structures of entities and functions, and use it in user scripts for example.
  • Flux installation guide
    This document provides instructions for Flux installation on supported platforms.
  • Flux Starting Guide
    Several short videos to start with Flux.
Notions
General knowledge:
I/O parameter (Input/Output): about
I/O parameter (Input/Output): table of results
Management
Commands for creation, modification and deletion:
New
Edit
Edit array
Delete / Delete in force
On this page
  • Notions
  • Management
© 2024 Altair Engineering, Inc. All Rights Reserved.
