Current value of an I/O parameter
Introduction
To recover a current value (value for a computation step):
- of an I/O parameter
- of a sensor
- of a kinematic quantity
- of a circuit quantity
the user can use the command Current value of an I/O parameter.
To recover a current value, follow instructions below:
| Step | Action |
| 1 | In the menu Advanced point on Current value of an I/O parameter |
| 2 |
In the dialog box Current value of an I/O parameter:
| 3 |
In the dialog box Editor of formula and I/O parameters choose:
| 4 | Modify the name of the default result (optional) |
The result is displayed in the History zone and is stored in the data tree. |
Equivalent commands
The sensors and the I/O parameters have each a command equivalent to the Current value of an I/O parameter command:
| Type of parameters | Equivalent command |
| Sensor | Create a result with current value of sensor |
| I/O Parameter | Create a result with a current value of an I/O parameter |
These commands are available in the contextual menu specific for various sensors and I/O parameters.
Storage
The result is stored as an entity in the tree of the general data in the type of entity Result under the root of the Post processing repertory.
If the calculation cannot be carried out for the resolution step chosen, the value is set to zero and an indicator informs the user: invalid result.
