Define Local Enclosure Controls
Use the Enclosure: Local tool to define local enclosure size settings on selected surfaces.
Generally, local size definitions are required where you want to capture small features. During the enclosure process, selected surfaces will be refined locally.
From the Discrete ribbon, click the tool.
- Select surfaces.
- In the dialog, define enclosure size settings.
From the guide bar, execute the command in the following
ways:
- Click
to confirm your selection and remain in the
tool.This allows you to continue creating instances and helps you visualize and edit instances with the legend.
- Click
to confirm your selection and exit the
tool.
- Click
Tip:
- The enclosure will be able to preserve gaps between parts/surfaces if the defined size is 1/3 the gap size.
- As a rule of thumb, define the minimum size as 1/3 of the smallest feature you need to capture.
