Define Proximity Refinement Controls
Use the Enclosure: Proximity tool to define proximity controls for the enclosure process.
In order to capture gaps locally without refining size everywhere, you can select surfaces where gaps should be preserved.
From the Discrete ribbon, click the tool.
- Select surfaces.
In the dialog, define a proximity tolerance.
All proximity above this value is removed. Thus, the proximity tolerance should be smaller than the gap you want to preserve.
From the guide bar, execute the command in the following
ways:
- Click
to confirm your selection and remain in the
tool.This allows you to continue creating instances and helps you visualize and edit instances with the legend.
- Click
to confirm your selection and exit the
tool.
- Click
