Define Mesh Controls
Use the Mesh dialog to define mesh settings.
From the Setup ribbon, click the
Advanced meshing parameters tool.
The Mesh dialog opens. -
In the Mesh dialog, define the desired mesh controls settings.
- Triangle plinth
- Create a plinth surface around single voxel gaps near the wind tunnel ground.
- Triangle splitting
- Activate triangle splitting of surfaces.
- Far field element size
- Coarsest element size.
- Refinement level transition layers
- Minimum number of elements to create between mesh refinement zones.
- Click Close.
