Evaluate
<Evaluate>
<runname>Ftg_SN_Run_4</runname>
<AnalysisLocation>ELEMENT</AnalysisLocation>
<CurveExtrapolate>True</CurveExtrapolate>
<HaighIntplMethod>Stress Ratio</HaighIntplMethod>
<ScaleLifeDamage>
<ScaleType>Damage</ScaleType>
<ScaleValue>1.000000</ScaleValue>
</ScaleLifeDamage>
<StaticFailChk>Continue</StaticFailChk>
<numprocessor>10</numprocessor>
<DamageSummary Opt="CSV">
<UserSetFile>E:/test/elem_list.csv</UserSetFile>
</DamageSummary>
<StsStnHis Opt="CSV">
</StsStnHis>
<CompLoadHis>Yes</CompLoadHis>
<LayerOutputFlag>Yes</LayerOutputFlag>
</Evaluate>
| Element Tag | Valid Values | Comment |
<runname> |
Run Name | Mandatory |
<AnalysisLocation> |
"ELEMENT" "NODE" |
Entity selection for Fatigue evaluation |
<CurveExtrapolate> |
“True” “False” |
Controls the extrapolation of SN curves |
<HaighIntplMethod> |
“Stress Ratio” “Mean Stress” |
This option is applicable when multiple Haigh diagrams are defined and controls the interpolation of multiple Haigh diagrams |
<StaticFailChk> |
“No
Check” “Continue” “Stop” |
Controls Static Failure options for Stress Life |
<safetyfactors> |
NA | Optional Compound Element |
<criterira> |
"Mean Stress" "Stress Ratio" |
NA |
<targetlife> |
Positive real value | NA |
<ScaleLifeDamage> |
<ScaleType> |
"Life" "Damage" |
<ScaleValue> |
Positive real value | Default = 1 |
<numprocessor> |
NA | Number of processors to run |
<DamageSummary Opt="None"> |
"None" | NA |
<DamageSummary
Opt="CSV">
"CSV" | Outputs EventswiseDamage.csv for the element/node list assigned |
<DamageSummary
Opt="Set">
"Set" | Outputs EventwiseDamage.csv for the element/node set assigned |
<StsStnHis Opt="None"> |
"None" | NA |
<StsStnHis
Opt="CSV">
"CSV" | Outputs Stress/Strain History per event for the element/node list assigned |
<StsStnHis Opt="Set">
"Set" | Outputs Stress/Strain History per event for the element/node set assigned |
<CompLoadHis> |
"Yes" "No" |
Output Compressed load history per event |
Output all Layers |
"Yes" "No" |
Contour results per Layer |
