Load Map
The event setup section is defined within this tag.
The load map section is defined
within:
<LoadMap>
</LoadMap>| Element Tag | Valid Values | Comment |
<LoadMapFile> |
Valid file path | Applicable for Duty cyle (.dcy)
file Applicable for LoadMap (.xml) file |
<Channel> |
<tabfat> |
Mandatory |
<FatigeEvents> |
Mandatory |
<Fatseq> |
<Fatevnt> |
Mandatory |
Time Series
Time Data Channels are defined
as:
<Channel>
<tabfat id="1" type="Time Data">D:/Sample_Load_path/load1.csv</tabfat>
</Channel>| Attribute | Valid Values |
| id | Valid ID |
| type | "Time Data" |
<tabfat> |
Valid load-history file path |
Define the Event
<FatigeEvents>
<Event Configuration="superposition" Gate="0" id="1" name="Event_1">
<Fatload LDM="1" Offset="0" Scale="1" block="1" resultfile="" sim="" subcase="1" tabfatId="1" tabfatName=""></Fatload>
</Event>
</FatigeEvents>
| Attribute | Valid Values | Comment |
| Configuration | "superposition" | Mandatory |
| Gate | 0 < Value < 1.0 | Mandatory |
| id | Valid ID | Mandatory |
| name | Valid name | Mandatory |
<Event> is defined with <Fatload>.| Attribute | Valid Values | Commend |
| LDM | LDM should be a non-zero value | Mandatory |
| Offset | Valid value | Mandatory |
| Scale | Scale should be a non-zero value | Mandatory |
| block | Valid value | Mandatory |
| resultfile | NA | Reserved for later use |
| sim | Valid value | Mandatory when simulation list from subcase is present |
| subcase | Valid value | Mandatory |
| tabfatId | Valid value | Mandatory |
| tabfatName | NA | Reserved for later use |
<Fatseq>
<Fatevnt EventId="" EventName="Event_1" Repeats="1"></Fatevnt>
</Fatseq>
| EventId | Valid value | Either event id or name is Mandatory |
| EventName | Event name | |
| Repeats | Valid value | Mandatory |
Transient
Transient events are defined
as:
<FatigeEvents>
<Event id="1" name="Event_1">
<Fatload resultfile="" subcase="1"></Fatload>
</Event>
</FatigeEvents>| Attribute | Valid Values | Comment |
<Event> is defined with <Fatload>.| Attribute | Valid Values | Comment |
<Fatseq>
</Fatseq>| Attribute | Valid Values | Comment |
| EventName | Event Name | |
Modal Superposition
Modal superposition channels are defined
as:
<Channel>
<ModalParticipationFactorFile>File_path</ModalParticipationFactorFile>
</Channel>| Element Tag | Valid Values |
<ModalParticipationFactorFile> |
Valid file path (.pch/.mrf/.abf) |
Define the Event
<FatigeEvents>
<Event id="1" name="ModalEvent_1">
<Fatload modal_channel="Subcase 1" resultfile="" sim="" subcase="1" tabfatId="" tabfatName=""></Fatload>
</Event>
| id | Valid ID |
| name | Valid event name |
| modal channel | Valid Subcase name | Mandatory |
<Fatseq>
<Fatevnt EventId="" EventName="ModalEvent_1" Repeats="1"></Fatevnt>
</Fatseq>
Random - PSD Stresses
Random events are defined
as:
<FatigeEvents>
</Event>
<Fatseq>
</Fatseq>
Random - Input PSD with FRF
Random analysis channels are defined
as:
<Channel>
<tabfat id="1" type="Input PSD:Real - Imaginary"> Fatigue_InputPSD/Input_PSD.csv</tabfat>
| id | Valid ID |
| type | Constant Amplitude |
<tabfat> |
Valid material file path |
Define the Event
<FatigeEvents>
<Fatload Excitation1="1" Excitation2="1" resultfile="" sim="" tabfatId="" tabfatName=""></Fatload>
<Fatload Excitation1="1" Excitation2="2" resultfile="" sim="" tabfatId="" tabfatName=""></Fatload>
<Fatload Excitation1="2" Excitation2="2" resultfile="" sim="" tabfatId="" tabfatName=""></Fatload>
</Event>
</FatigeEvents>
| Excitation1 | Valid value | Mandatory |
| Excitation2 | Valid value | Mandatory |
| sim | NA | Reserved for later use |
| tabfatId | Valid value | Optional |
<Fatseq>
<Fatevnt EventId="" EventName="Event_1" ExposureTime="1"></Fatevnt>
</Fatseq>
| ExposureTime | Valid value | Mandatory |
Sine Sweep
Sine Sweep analysis channels are defined
as:
<Channel>
<tabfat id="1" scale="0.1" type="Constant Load"></tabfat>
| id | Valid ID |
| scale | Scale should be a non-zero value (NA for Variable Scale) |
| type |
"Constant Load" "Variable Scale" |
<tabfat> |
Valid file path (NA for Constant load) |
Define the Event
<FatigeEvents>
<Fatload resultfile="" sim="" subcase="3" sweeprate="1" sweeprateunit="HZPSEC" tabfatId="1" tabfatName=""></Fatload>
</Event>
</FatigeEvents>
| sweeprate | Valid value | Mandatory |
| sweeprateunit |
"HZPSEC" "OCTPMIN" |
Mandatory |
| tabfatId | Valid ID | Mandatory |
| tabfatName | Valid name | NA |
<Fatseq>
<Fatevnt EventId="" EventName="Event_1" sweeps="1"></Fatevnt>
</Fatseq>
| sweeps | Valid value | Mandatory |
