hm_getwindowarea
Returns the x, y, width and height of a window.
hm_getwindowarea
HyperMesh Tcl GUI Command
This command returns the x and y coordinates that define the upper left corner along with the width and height of a window. The x and y values are relative to the upper left corner of the HyperMesh window, not the entire screen.
- option
- interactive - allows you to define the window by pressing the left mouse button and dragging a selection.
To prompt you to drag a window and copy the window area to the clipboard:
foreach {x y w h} [hm_getwindowarea interactive] {
hm_windowtoclipboard $x $y $w $h
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
