hm_windowtoclipboard
Capture a rectangular area of the screen and save it to the clipboard.
hm_windowtoclipboard x y width height
HyperMesh Tcl GUI Command
This command saves to the clipboard the rectangular window area specified by you.
This command is only available and supported on Windows.
- x
- The upper left window corner x-coordinate. This is relative to the root window.
- y
- The upper left window corner y-coordinate. This is relative to the root window.
- width
- The width of the window in pixels.
- height
- The height of the window in pixels.
To get the modeling window coordinates and copy the modeling window to the clipboard:
foreach {x y w h} [hm_getgraphicsarea] {}
hm_windowtoclipboard $x $y $w $h
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
