hm_launchhb
Launches the HyperBeam GUI with a specified beam section loaded by default.
hm_launchhb ?beam_section_id?
HyperMesh Tcl GUI Command
- beam_section_id
- The ID of the beam section to load by default when launching the GUI. If not specified, the first section is loaded.
To launch the GUI with beam section ID 10 loaded by default:
hm_launchhb 10
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
