hm_registerredraw
Specifies if markers and shapes should be redrawn when the associated entity is modified.
hm_registerredraw mode
HyperMesh Tcl GUI Command
- mode
- 0 - Do not redraw
Examples
To enable redrawing of markers and shapes:
hm_registerredraw 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019.1
