hm_winfo
Returns the value of certain HyperMesh window settings.
hm_winfo option
HyperMesh Tcl GUI Command
This command returns the value of certain HyperMesh window settings.
- option
- The option to query. Valid values are:
- x - Window x location in pixels
- y - y location in pixels of the upper left of the modeling window
- width - Window width in pixels
- height - Window height in pixels
- graphicx - x location in pixels of the upper left of the modeling window
- graphicy - y location in pixels of the upper left of the modeling window
- graphicwidth - modeling window width in pixels
- graphicheight - modeling window height in pixels
- headlineheight - Headline area height in pixels
- borderwidth - Window border width in pixels
- menuheight - menu bar height (not including control card) in pixels
- viewmatrix - Returns the coordinates and scaling of the display area. These values are the same as those used by *viewset.
- entitycolors ?index? - If an index 1 through 64 is specified, returns a list of 3 RGB values for that color. If no index is specified, returns a list of RGB triplets for all colors.
- color index - Returns the RGB color value for the specified widget index.
To get the width of the graphics area:
set w [ hm_winfo graphicwidth ]
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
2023 - Deprecated option utilitywindow. Removed options hasfocus, isobscured, menucharheight, and menulines.
