mark assembly
Marks assemblies.
mark assembly all
mark assembly clear argument
mark assembly <dictionaryrange>
mark assembly displayed
mark assembly <label>
mark assembly <labellist>
mark assembly <range>
mark assembly select
Arguments
- all
- Mark all assemblies.
- clear
- Clear all assemblies.
- all
- Clear all assemblies from mark.
- dictionaryrange
- Clear assemblies from mark with names between {[<start>,} <end>\].
- displayed
- Clear displayed assemblies from mark.
- <range>
- Clear by component ID.
- select
- Clear selected assemblies from mark.
- dictionaryrange
- Mark assemblies with names between <start> and <end>.
- displayed
- Mark displayed assemblies.
- <label> <labellist>
- Marks assemblies based on labels or lists (wildcards supported). For
example,
"Rigid Barrier", Bump??, back*andhinge, handle. - <range>
- Mark assemblies by ID.
- select
- Mark assemblies by selection, interactively selected from the modeling window.
Clear marked assemblies between a defined start and end
range:
mark assembly clear dictionaryrange "ASSEMBLY 1" "ASSEMBLY 4"Mark all assemblies:
mark assembly allMark displayed assemblies:
