mark measure
Marks measures.
mark measure all
mark measure clear argument
mark measure <dictionaryrange>
mark measure displayed
mark measure <label>
mark measure <labellist>
mark measure <range>
mark measure select
Arguments
- all
- Mark all measures.
- clear
- Clear all measures.
- all
- Clear all measures from mark.
- dictionaryrange
- Clear measures from mark with names between {[<start>,} <end>\].
- displayed
- Clear displayed measures from mark.
- <range>
- Clear by measure ID.
- select
- Clear selected measures from mark.
- dictionaryrange
- Mark measures with names between <start> and <end>.
- displayed
- Mark displayed measures.
- <label> <labellist>
- Marks measures based on labels or lists (wildcards supported). For
example,
"Measure *", Measure2, MyMeasure*and"Measure *", Measure2, MyMeasure*. - <range>
- Mark measures by ID.
- select
- Mark measures by selection, interactively selected from the modeling window.
Clear marked measures between a defined start and end
range:
mark measure clear dictionaryrange "Dynamic MinMax Result" "Static MinMax Result"Mark all measures:
mark measure allMark displayed measures:
