mark note
Marks notes.
mark note all
mark note clear argument
mark note <dictionaryrange>
mark note displayed
mark note <label>
mark note <labellist>
mark note <range>
mark note select
Arguments
- all
- Mark all notes.
- clear
- Clear all notes.
- all
- Clear all notes from mark.
- dictionaryrange
- Clear notes from mark with names between {[<start>,} <end>\].
- displayed
- Clear displayed notes from mark.
- <range>
- Clear by note ID.
- select
- Clear selected notes from mark.
- dictionaryrange
- Mark notes with names between <start> and <end>.
- displayed
- Mark displayed notes.
- <label> <labellist>
- Marks notes based on labels or lists (wildcards supported). For example,
"Note *", Note2, MyNote*and"Note 1",Note2, MyNote*. - <range>
- Mark notes by ID.
- select
- Mark notes by selection, interactively selected from the modeling window.
Clear marked notes between a defined start and end
range:
mark note clear dictionaryrange "node 1 Node 91" "node 1 Node 118"Mark all notes:
mark note allMark displayed notes:
mark note displayed
