mark component
Marks components.
mark component all
mark component clear argument
mark component <dictionaryrange>
mark component displayed
mark component <range>
mark component select
Arguments
- all
- Mark all components.
- clear
- Clear all components.
- all
- Clear all components from mark.
- dictionaryrange
- Clear components from mark with names between {[<start>,} <end>\].
- displayed
- Clear displayed components from mark.
- <range>
- Clear by component ID.
- select
- Clear selected components from mark.
- dictionaryrange
- Mark components with names between <start> and <end>.
- displayed
- Mark displayed components.
- <range>
- Mark components by ID.
- select
- Mark components by selection, interactively selected from the modeling window.
Clear mark components between a defined start and end
range:
mark component clear dictionaryrange "BEAm: DRIVE-SHAFT" "BEAm: RAIL-CONN-BACK"Mark all components:
mark component allMark displayed components:
