plt3DIPlot GetAspectRatioLocked
Gets whether the axis ratios are locked.
plt3DIPlot_handle GetAspectRatioLocked
Tcl Query
The aspect ratios of the axes can be set explicitly. The X axis is assumed always to have a length of one, with Y and Z axes having individual values associated with them to define the ratios. Once set, the ratios can be frozen by calling SetAspectRatioLocked. If not locked, the ratios may be changed by manipulations of the GUI.
Returns true or false.
To check if the axes box is included during fit
operations:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetAspectRatioLockedErrors
None.
