plt3DIPlot SetAspectRatioLocked
Sets whether the axis ratios are locked.
plt3DIPlot_handle SetAspectRatioLocked locked
Tcl Query
The aspect ratios of the axes can be set explicitly. The X axis is assumed always to have a length of one, with Y and Z axes having individual values associated with them to define the ratios. Once set, the ratios can be frozen by calling SetAspectRatioLocked. If not locked, the ratios may be changed by manipulations of the GUI.
- locked
- Keep axes fixed, true or false.
To freeze the aspect ratios in the current
state:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName
myClientName SetAspectRatioLocked true
myClientName DrawErrors
None.
