plt3DIPlot SetClipTransparency
Sets whether clipped data is partially visible (displayed transparently).
plt3DIPlot_handle SetClipTransparency enabled
Tcl Query
Data, in the form of waterfalls, curves, or surfaces, can be clipped with planes. The undisplayed portion of the data can be rendered partially visibible by means of this flag.
- enabled
- Display clipped data as transparent, true or false.
To turn off the visibility of an existing
surface:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName
myClientName SetClipTransparency true
myClientName DrawErrors
Success (0) or an error code.
