plt3DIPlot GetIncludeAxesInFit
Gets whether clipped data is partially visible (displayed transparently).
plt3DIPlot_handle GetIncludeAxesInFit
Tcl Query
In box axis mode, by default, the axes box is included in bounding box calculations, so as to keep it visibile when a fit operation occurs. Turning this flag off causes the plot to appear larger after a fit operation, but parts of the axes box may not be visible.
Returns true or false.
To check if the axes box is included during fit
operations:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetIncludeAxesInFitErrors
None.
