plt3DIPlot GetClipTransparency
Gets whether clipped data is partially visible (displayed transparently).
plt3DIPlot_handle GetClipTransparency
Tcl Query
Data, in the form of waterfalls, curves, or surfaces, can be clipped with planes. The undisplayed portion of the data can be rendered partially visibible by means of this flag. Returns true or false.
- axis
- The axis from which to get the category.
- idx
- The index of the category.
To check if clipped data is displayed as
transparent:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetClipTransparencyErrors
None.
