poI3DViewCtrl GetCropping
Gets the number of pixels cropped from each side of the image plane associated with the view.
poI3DViewCtrl_handle GetCropping name
HyperView Tcl Query
Returns a string consisting of top, bottom, left, and right values. These values represent numbers of pixels pre-cropped from each corresponding side of the image plane. Captured videos/images are often processed before using them for video overlaying, one typical process is cropping the borders of a video/image.
- name
- If specified, the offset of the view with that name will be returned. Otherwise, the current view’s offset will be returned.
To get the cropping values of a view named "View 1":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle GetCropping "View 1"
hwi CloseStackError
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist.
