poI3DViewCtrl SetSensorHeight
Sets the sensor height of a stored view.
poI3DViewCtrl_handle SetSensorHeight height name
HyperView Tcl Modify
This command sets the sensor height of a stored view. This value simulates the sensor height of a camera lens.
- height
- Value in mm of simulated lens sensor height. This value must be greater than 0.
- name
- String specifying the name of the view to be modified. If a name is not specified, the current view will be modified.
To set the sensor height of a view named "View 1" to
15.6:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle SetSensorHeight 15.6 "View 1"
hwi CloseStackError
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist or if the height is less than or equal to 0.
