poI3DViewCtrl GetSensorHeight
Gets the sensor height of a stored view.
poI3DViewCtrl_handle GetSensorHeight name
HyperView Tcl Query
This command retrieves a float number representing the sensor height in mm. This value simulates the sensor height of a camera lens.
- name
- If specified, the height of the view with that name will be returned. Otherwise, the current view’s height will be returned.
Get the sensor height of a view named “View
1”:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle GetSensorHeight "View 1"
hwi CloseStackError
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist.
