poI3DViewCtrl SetActiveView
Sets a view as active or not active.
poI3DViewCtrl_handle SetActiveView active name
HyperView Tcl Modify
In order to edit a stored view, it must be marked as active. Only one view, other than the current view, can be marked active. Whatever is currently displayed in the window will always be the same as the active view.
- active
- Boolean value that specifies whether to activate or deactivate a view.
- name
- Specifies the name of the view to be activated.
To set "View 1" as
active:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle SetActiveView true "View 1"
hwi CloseStackError
Returns HW_InvalidHandle if the view handle is invalid.
