poI3DViewCtrl GetUpOrientationMethod
Gets the orientation method of the camera top position.
viewControl_handle GetUpOrientationMethod name
HyperView Tcl Query
Returns the orientation method used to define the camera top position.
- name
- String specifying the name of the view to be queried. The current view will be queried if a name is not specified.
To get the orientation method defined for a view named "View
1":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
set orient_method [view_handle GetUpOrientationMethod "View 1"]
hwi CloseStackError
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist or is an invalid type.
