poIContourCtrl GetCurrentPlotStyle
Gets the current plot style.
poIContourCtrl_handle GetCurrentPlotStyle
HyperView Tcl Query
This command retrieves the current active plot style set on the contour controller.
Note: An
empty value is returned if a current plot style is not set.
To get the current contour plot
style:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
contour_handle GetCurrentPlotStyle
hwi CloseStackError
Returns an error if the contour controller handle is invalid.
