poIContourCtrl GetThresholdMax
Gets the maximum threshold value of the contour.
poIContourCtrl_handle GetThresholdMax
HyperView Tcl Query
This command retrieves the maximum threshold value of the contour.
To get the maximum threshold value of the current contour
plot:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myResultName GetContourCtrlHandle myContourName
myContourName GetThresholdMaxError
Returns the current maximum threshold value, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
