poIContourCtrl GetOffset
Gets the current contour offset value (lowest scale in the legend).
poIContourCtrl_handle GetOffset
HyperView Tcl Modify
This command returns the current contour offset value (lowest scale in the legend).
To get the current offset
value:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myResultName GetContourCtrlHandle myContourName
myContourName GetOffsetError
Returns the offset value, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
