poIContourCtrl SetValueFilterEnableState
Sets the state of the contour value filter.
contour_handle SetValueFilterEnableState state
HyperView Tcl Modify
This command sets the value filter state for the contour.
- state
- The boolean value to set the value filter state (True or False).
To set the value filter state for a
contour:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Sets the value filter state to true
contour_handle SetValueFilterEnableState true
hwi CloseStackError
Returns an error if the value state cannot be applied.
