poIContourCtrl RemovePlotStyle
Removes a plot style with the specified name.
poIContourCtrl_handle RemovePlotStyle style_name
HyperView Tcl Modify
This command removes the specified contour plot style.
- style_name
- The name of the contour plot style to be removed from the existing style list.
To remove the specified contour plot
style:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
contour_handle RemovePlotStyle "style_name"
hwi CloseStackError
Returns an error if the contour controller handle is invalid, or if the plot style name could not be found.
