poIResultMathCtrl AddResource
Adds an external resource file to the current model.
rmath_handle AddResource res_name file_path
HyperView Tcl Modify
This command adds an external resource file to the current model. An external resource file is typically an xml file which contains additional tables like: material yield, thickness table, etc. This command is generally used when you would like to access some of these external table values along with tables from the model/result file.
- res_name
- The name for the resource (which must be unique).
- file_path
- The complete path of the file name.
To create a selection set containing all nodes and make it visible in the graphics
area:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
rmath_handle AddResource External c:/external_table.xml
hwi CloseStackErrors
Returns a non-zero value if an error occurs.
