poIResultMathCtrl GetAlias
Gets the alias string for the passed string.
rmath_handle GetAlias delim str
HyperView Tcl Query
This command retrieves the alias string corresponding to the input string. This string is
used by the result math expression builder to display a table specification in short hand
form. In order for this command to work, the input string should contain the following six
values:
- Resource name
- Subcase ID
- Simulation index
- Datatype name
- Datacomponent name
- Layer name
Note: If you do not want to specify a particular field for a table specifier, that
field must be left blank. See the usage of this command for the bumper d3plot model in the
example section below.
- delim
- The delimiter string used to separate the different fields of a table specification.
- str
- The input string for the desired alias.
To create a selection set containing all nodes and make it visible in the graphics
area:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
rmath_handle GetAlias "#" "Model#1#4#Stress#XX#Lower#"
rmath_handle GetAlias "~" "Model~1~3~Stress~ ~ ~"
hwi CloseStackErrors
Returns an empty string if an error occurs.
