poIResultMathCtrl GetEquationModeList
Gets a list of possible modes which can be used with the GetEquation command.
rmath_handle GetEquationModeList
HyperView Tcl Query
This command returns a list containing the possible modes which can be used with the
GetEquation command {alias original xml}.
Note: The mode "xml" can not
be used while using the SetEquation command.
To get the equation mode
list:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set eid [rmath_handle AddExpression]
rmath_handle GetExpressionHandle expr_handle $eid
expr_handle GetEquationModeList
hwi CloseStackErrors
None.
