poIResultMathCtrl GetEquation
Gets the result math equation string.
rmath_handle GetEquation mode
HyperView Tcl Query
This command retrieves the math equation.
- mode
- The mode can have a value of: "alias", "original", or "xml".
To get the math equation associated with a result math
expression:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set eid [rmath_handle AddExpression]
rmath_handle GetExpressionHandle expr_handle $eid
expr_handle SetEquation {T1+2} alias # alias form
expr_handle GetEquation alias
expr_handle GetEquation original
expr_handle GetEquation xml
hwi CloseStackErrors
None.
