poIResultMathCtrl GetSimulationLabel
Gets the label of a particular simulation.
rmath_handle GetSimulationLabel resource_name sub_id index
HyperView Tcl Query
This command retrieves the label of a particular simulation.
- resource_name
- The name of the resource.
- sub_id
- The ID of the subcase.
- index
- The index of the simulation whose label is needed.
To get the label of a
simulation:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set res_list [rmath_handle GetSimulationLabel model 2 0]
hwi CloseStackErrors
None.
